Oil Consumption at 76k miles
Old 07-08-2014, 12:21 PM
N777CK T's Avatar
Ok, the plugs seemed normal when I took the old ones out, luckily I filmed it so I can see. Please check the end of the video from 4mins 47secs and let me know. They looked normal to me but not sure what the sign of burning oil looks like on the plugs?
Appreciate your help!
I was debating on running different or thicker oil next :/
Old 07-08-2014, 12:22 PM
N777CK T's Avatar
Sorry forgot the link! Video is here: http://youtu.be/Q5-7FaQSfP4
Old 07-08-2014, 12:25 PM
N777CK T's Avatar
Actually here is the screenshot so you don't have to watch the spark plug tutorial lol
What do you think? I guess if you can't tell from this photo it's a compression test next...
Old 07-08-2014, 01:20 PM
AZfury's Avatar
Bad wrist pins, bad crankshaft bearings, bad rings, I've seen em all on ap1's
Old 07-08-2014, 01:25 PM
bgoetz's Avatar
Or it is just an AP1 that uses oil, like many other perfectly healthy AP1s in this world!!!! Why does something have to be wrong when this is VERY common!
Old 07-08-2014, 01:27 PM
N777CK T's Avatar
Yeh, where does it officially say the 'oil consumption tolerance' that Honda say is OK?
Old 07-08-2014, 02:08 PM
xdavieexx's Avatar
Check your PCV if it is clogged or not. I changed mine out and consumption went down. Probably because there is less pressure in the valve case that is forcing oil through your piston rings.
Old 07-08-2014, 02:53 PM
bgoetz's Avatar
Search man!! There are hundreds of threads dating back to 2000 where new cars were going through a quart every 1k. This very well may be the most common "issue" if you want to call it an issue on this entire board. If it runs fine, does not blow smoke, and has solid compression just add oil when needed.
Old 07-08-2014, 02:54 PM
bgoetz's Avatar
And always read the low side of the dipstick.
Old 07-08-2014, 02:57 PM
bgoetz's Avatar
FWIW my 2001 has been 1qt/1k since the previous owner purchased it @ 40k miles. It now has 133k and guess what 1qt/1k. If it were an issue the motor would have been toast long ago. My compression, 235 solid across all 4 cylinders.
Quick Reply: Oil Consumption at 76k miles
