Oil consumption
First thing I'd try is the correct oil filter.
Oil pressure in the S2000 engines can overwhelm generic non-OEM oil filters, incorrect gaskets and poor tightening. Hint: It's impossible for mere mortals to properly hand tighten the oil filter on the S2000 even IF it's the right filter which this one ain't.
-- Chuck
-- Chuck
Number one cause of S2000 demise = wrecks
Number 2 is probably running low on oil then going redline
Number 3, I bet its engine fires from oil filter not torqued down properly (or aftermarket filter which is impossible to torque down beyond normal hand tight (as that would distort gasket and it'd leak badly).
You need the correct Honda filter, and follow closely instructions written on side of filter. As stated, its impossible to comply with these instructions just using hands. You must use a filter socket and wrench.
If there are any humans that can do it by hand, they'd never fit inside an S.
This pic was a little old, this was before I changed the oil. I was having a hard time finding parts locally, so I used a Mobil 1 filter while waited for my oe filters to arrive in the post. I posted this pic but I was trying to hang a video I recorded that shows the wet bolts on the VTEC and the rubber hoses coming off the oil filter. If I can figure it out, I will like the video from my FB page.
windhund116 (09-03-2023)
I can't open your link. I don't have Facebook or Meta (I'm a practing Luddite ).
I went to road test, let the engine get up to temp, then ease into vtec in 3nd. Hit the fuel cut (crap). Pulled off, forgot to connect the vtec. Plugged it all back up but then the ecu was holding onto the code (for got the number) and still wouldn't let me get into vtec. Went to the parts store, confirmed 2 codes, vtec, catalytic converter (known). Asked them to clear, apparently they can't do that anymore. Disconnected battery, cleared codes. take a breath.
Now she is running sweet as a top! fells berry smooth all the way through the power band.
Only issue I have now is I can't figure out how to input a Zero "0" for my radio security code. Other than that, very happy with the work and result today.
Step one: press 1 and 6 Simultaneously WHILE pressing the power button turning it ON (it doesn't matter if you do this with the car running/driving/or just with the key in the on position, it all works the same). It will turn on displaying your 8 digit serial number.
Step two: write it down.
Step three: call this number 1-800-999-1009 its pretty much direct! Press a couple buttons, you get a live person, they ask for the vin, tell you what car it pulls up in their system (it'll be yours, and they'll know if your the original owner or not) you agree, they'll update your info if you wish, tell him your serial number, then they'll tell you the code.
Step three: punch it in, and bam, you haz music again!
Step four: WRITE DOWN THE CODE!!!
