Oil consumption
Old 03-20-2024, 06:49 AM
  #111
B serious's Avatar
Received 1,418 Likes on 1,052 Posts
Originally Posted by Chuck S
You're topping up to Max when it's only down a bit or only adding oil when it's at the low mark? See post 117.
-- Chuck
A post from the future? What does it hold?
Chuck S (03-20-2024)
Old 03-20-2024, 06:53 AM
  #112
B serious's Avatar
Originally Posted by Dibsen
in the last 3k miles, I’ve added 2qt. So I guess I am under the qt/1000mile tolerance. Got to admit, I’d love my car more if it could hold its liquid.
That's not a concerning amount of oil consumption.
But there are some easy items to try and improve this condition...
Clean or replace the PCV valve. If you buy a new one, make sure its from a Honda dealer.
Switch oil brands or weights. My AP1 tends to go through 2qts of Mobil1 10W30 per 3K miles. But I can either half that or completely eliminate it by using Castrol Syntec (Black Bottle) 0W40 or 10W30.
One thing to remember since you're tracking the car. Hard right handers (especially when followed by hard left handers) will cause oil slosh within the valve cover and will cause a large amount of oil to be sucked into the intake manifold, and then burned by the engine.
If you see smoke behind you after hard right handers, you should really consider a solution, as the large amount of liquid oil being inhaled by the engine can cause damage.
PalenkosBro
11-11-2023 05:59 AM
rvittori
08-25-2023 04:06 AM
Sam-S2K
07-28-2022 08:37 AM
A. Dos Santos
04-29-2017 04:59 PM
fokissed
06-19-2008 02:10 PM
Quick Reply: Oil consumption
