Oil change question & observations
Old 08-31-2004, 12:27 PM
lamvu's Avatar
what size fitting is it?.... i looked but i want to be sure if it the correct fitting or not.
Old 08-31-2004, 12:48 PM
Celeritas's Avatar
I have a fumoto valve on mine, and find that it is easiest to lay down by the front passenger wheel and get it from underneath. That way I don't risk leaning too hard on the fender whle reaching down from above. Either way, the jack is not required. Fumoto valve highly reccomended.
Old 08-31-2004, 01:34 PM
JNT Handyman's Avatar
Not sure if this is what you're asking for, but the part numbers on the fumoto site are:
F-106 for the valve itself & ADP106 for the required adaptor. It was $28.95 plus a couple of dollars for shipping. If you change your own oil, it's well worth it. It will save you a lot of time & mess.
Another good thing about the valve is that you can easily take oil samples between oil changes from your engine to send to blackstone or whoever you use if you're into oil analysis.
JNT Handyman.
Old 08-31-2004, 06:06 PM
Scablander's Avatar
Question about the Fumoto valve...is the valve upright after the install? It appears that the valve has fixed threads. After the valve is tightened completely is the valve oriented as shown in the pictures on the Fumoto site, or is the valve cocked at some goofy angle at random based on orientation of the threads in the oil pan or on the valve? Additionally, the Fumoto site does not show a picture of the adaptor. How does the adaptor attach to the valve?
Thanks for any info.
Old 08-31-2004, 08:15 PM
[QUOTE=Scablander,Aug 31 2004, 08:06 PM] Question about the Fumoto valve...is the valve upright after the install?
Old 09-01-2004, 08:13 AM
WPS
WPS's Avatar
i had the valve but returned it. the threads are fixed so mine ended up with the lever down. it felt unsafe and i figured it very easy to take out a drain bolt. '
i don't know how ppl can reach the valve from the top. must be my muscles getting in the way
S2Kmonkee
22
11-21-2008 03:42 PM
iljw
12-01-2007 12:49 PM
hipopkboy
10-17-2007 03:07 PM
tomspedale
03-08-2002 11:39 PM
jallen1217
04-30-2001 08:02 PM
Quick Reply: Oil change question & observations
