Oil change question on 2008 ?
Old 11-25-2008, 09:03 AM
dedonderosa's Avatar
Default Oil change question on 2008 ?
ok well heres the deal i got my 08 s2k in at the end of june and i was gonna do the 1st oil change at 5k miles. now heres the thing its almost winter and i have 3600 miles on the car now (yea i know i dont drive much) anyway should i change the oil now anyway before winter?? Im just worried bout taking out that break in oil too soon. but its suppose to be 5 months or 5k miles and its 5 months. and yes i know oil breaks down over time. but just wanted to get some opinons on if i should change it now or wait till 5k miles??? also i wanted to keep good maint. records. thanks
Old 11-25-2008, 09:36 AM
EP Heart's Avatar
I was basically in the same boat as you (brand new '08 bought in June) except I only had 2,2xx miles on it by the time I winterized it. I asked this question a few times here and there are varying opinions on what people may tell you.
As for what I chose to do, I chose to leave it in. That's what the winterizing thread suggested if you have really low miles on the factory fill like I do. Besides, my garage is now way too cold for me to change my mind.
However, I'd be inclined to think that if I had the same mileage as you, I probably would've changed it out before putting it away for winter.
Old 11-25-2008, 09:48 AM
yea also my main concern is keeping the maint. records so......
Old 11-25-2008, 10:17 AM
dparm's Avatar
What's the factory fill (weight/viscosity)? You don't want something too thick in there for the winter.
Also, where are you located? Just want to gauge how low your temps will get.
Old 11-25-2008, 11:21 AM
im from nj. so what u think? should i change the oil or leave it in there till spring???.... if im gonna change it im just gonna use castrol GTX cause i hear it has good amts of moly in it.
Old 11-25-2008, 01:20 PM
dparm's Avatar
You didn't answer my question -- what weight/viscosity is in there right now?
Old 11-25-2008, 01:23 PM
EP Heart's Avatar
What's the weight/viscosity written on the cap and user manual, 10w30? I assume that's what the factory uses, as well. I'm under the impression that he's on the factory fill.
Old 11-25-2008, 02:38 PM
my_slow_2k's Avatar
Why would that even matter if the car would be parked?
I would leave it in, then change it in the spring. That's my route I am taking. I have about 1600 miles until my next change.
Old 11-25-2008, 04:39 PM
yea its factory fill 10w30 but eveyone i've talked to said 5000 miles or 5 months. cause oil still breaks down over time
Old 11-25-2008, 05:54 PM
cdelena's Avatar
The oil does not break down but does pick up a little moisture over time. Usually a change can wait a year and since the factory fill does contain additives that aid in break-in I would leave it until next year.
Quick Reply: Oil change question on 2008 ?
