OIL change mishap
OIL change mishap
So, this is my first time trying to use those vaccum oil tube sucking things. I inserted the tube thru the dip stick but now it won't come out.
any suggestions?
i'm pretty close to just dropping the oil pan...anyone have tips/instructions for this?
thanks =(
any suggestions?
thanks =(
oh god drain plug fo sho next time....but right now i'm a bit ****ed =\
So u think removing the valve cover will help? I'm like 2ft of hose in....i'm thinking oil pan is the only way?
is there anything that i could be wrapped around? is it a bad idea to yank super hard?
there's 2ft of tube inside my car, thru the dip stick spot. the idea is that its like a straw sucking out the oil so lazy dumbasses (like myself) dont' need to get under the car. lesson learned.
can anyone think of any reason why i should yank as hard as possible?
anyone every change the oil pan before?
