oil change frequency for garage queen + stabilizer question
Hi all, hope this is the right place for this question. I've never really driven my car all that much, averaging about 2,000 miles a year (maybe not garage queen status but low miles )but with the things that happened last year i really didn't drive all that much and was wondering how often I should be getting oil changes and what type of oil should I be using in this type of scenario? i've used both penzoil plat and mobil 1 in the past.
A follow up question is a buddy I was talking to mentioned this product: STA-BIL 360 Protection Ethanol Treatment And Fuel Stabilizer. Is this something I would need? I drive my car for about 10-15 minutes at least once a week. thanks all!
Received 1,377 Likes
Hard to know what the best thing to do is here, since you're using the car in bit of a detrimental way.
10-15mins isn't long enough to get everything up to temp. So you're just kinda half-cycling it once a week. So its probably got a good amount of moisture in it.
Maybe just change it every 6 months or so.
Idk why you want to know what type of oil to use. But...enjoy the debate!
I would just use a top teir gasoline and skip the additives, to answer that question.
rizzllzahid (03-31-2021)
You can draw oil out of the dipstick hole with a little vacuum device. Send the sample to Blackstone Labs. Indicate you're interested in extended oil service and see what they recommend. If you're not using full synthetic switch to it.
From your owners manual:
-- Chuck
If possible, periodically run the
engine until it reaches full
operating temperature (the
cooling fan cycles on and off
twice). Preferably, do this once a
month.
month.
Received 1,718 Likes
Adding the correct amount of Sta-Bil will not hurt anything and you may consider keeping the tank topped off too to keep air/moisture out of the system. (Don't go bananas "topping off" of the tank when filling-you can dick up the evaporator system. Just fill to the pump clicking off)
Also agree on the run time. At least 20 minutes drive is a minimum. Find some fun destination to do and go once a month or something. For the winter or wet months, I use a battery minder to keep the battery up to speed.
I default to 6 months if not driven at most for an oil change.
have never used fuel stabilizer in any car I have owned even if it sits over the winter like my s2k. If leaving sit for 12+ months I would consider it but mine typically sits from Nov - April.
The issue with starting and running it 15-20 min is that you do not get much benefit and are just adding more cold starts. Most recommend at least a 20-30 drive (not just idling) or nothing at all. Like some others on here, I just keep mine on a battery tender all winter. If I need to move it for some reason it gets started, but since I pretty much only own extreme performance summer tires for it I dont drive it around in the winter.
You're in los angeles - fairly low humidity region. Since you said garage queen, i'm assuming indoors parking. The main enemy is moisture in your oil.
I've let oil sit in my car for as long as 15-16 months and have even tracked on it. I then sent to blackstone labs and it came out fine - definitely not best practice. Car is mostly a track toy and rarely gets much driving in between events now - life, kid, etc. - mainly kid...
FYI, i'm also located in SoCal. If i live close to the ocean or a high humidity region like Florida or something, I would definitely change more often.
