Oil change - forgot to put on crush washer
Old 11-04-2007, 04:39 AM
  #21
way2low01's Avatar
I did the same thing my last oil change. I said screw it. Ive kept an eye on my oil level and I havnt lost any. Been over 2k miles ago.
Old 11-04-2007, 05:06 AM
  #22
Billman250's Avatar
Received 1,403 Likes on 840 Posts
I've had plenty of s2ks come in with no washer, it won't leak it will be fine. The aluminum oil pan will always seal perfectly.
However.... when tightening the bolt, any overtightening you do will act directly on the threads of the oil pan instead of crushing the washer.
If it were mine, I'd leave it and put the washer in next time around.
If you are not good with tightening drain bolts, then definitely pull it back out and use the washer.
Old 11-04-2007, 06:10 AM
  #23
Tyraid2K's Avatar
I've been running the same washer for the last 3 oil changes, do it right, get it pointed the right way, and its not as big a deal as everyone would like you to think
never had an oil leak, maybe the only thing that hasn't leaked outa my car
Old 11-04-2007, 06:38 AM
  #24
CoralDoc's Avatar
As Billman mentioned, the washer makes it easier to torque the bolt properly. For that reason alone, I use a new one about every other oil change.
3 changes won't be too bad, but here's what happens when you get greedy and try to use one too many times. I took the washer on the left off a friend's Civic. It was leaking oil.
Old 11-04-2007, 06:48 AM
  #25
HARDtoTOP's Avatar
re-using washers. Jeez. These things cost about $.25. Why is everyone so cheap
Old 11-04-2007, 07:58 AM
  #26
joey1320's Avatar
Old 11-04-2007, 08:26 AM
  #27
stopmenot2002's Avatar
I think reuse the washer 2nd or 3rd time is ok, just put it back the way it was.
Old 11-04-2007, 11:08 AM
  #28
indus's Avatar
Old 11-04-2007, 02:44 PM
  #29
HARDtoTOP's Avatar
So that brings the question...
Why do you guys reuse if they are so cheap for a new one and you need to go to the dealer anyhow to get the filters?
Old 11-04-2007, 05:56 PM
  #30
ShocK's Avatar
My dealer tapes them to the filter.
Quick Reply: Oil change - forgot to put on crush washer
