Oil change - forgot to put on crush washer
Old 11-03-2007, 07:31 AM
slalom44's Avatar
Here's what I did when I did this on a Civic years ago:
Partially unscrew the drain plug - not all the way. Get some Teflon tape from a Hardware store (used to seal threaded plumbing and gas line joints) and wrap it around the unscrewed section. It doesn't have to be neat or flat, just as long as it's in there. Put about 8 wraps around this area, cut it off, and tighten the drain plug.
The teflon tape will seal like a gasket and prevent leaking.
Another option that I've never tried but should work: Instead of wrapping teflon tape, you should be able to get a garden hose washer to fit in there. You'd have to stretch it around the head of the drain bolt when it's loosened, then tighten it after it's inside. You have to make sure it doesn't bulge out on one side when you're tightening it. FYI - the ID of the crush washer is exactly the same as the ID on the garden hose washers I have.
Old 11-03-2007, 08:26 AM
HARDtoTOP's Avatar
It's just oil. Pull the plug and replace the washer, if you lose 3 qts, put 3 qts back.
Old 11-03-2007, 10:42 AM
deathsled's Avatar
for the record I have never replaced the crush washer when doing an oil change. Also, my stealth and 3000gt don't even have them (dont know if this is a material/design difference) and they never leaked (for what I could tell).
Old 11-03-2007, 10:43 AM
Sponsor
Vendor - Starter Primary
JS2k.com's Avatar
lol thanks guys
I forgot I could reuse the oil that drained.
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
Old 11-03-2007, 02:29 PM
ShocK's Avatar
Originally Posted by ESCALVANTE,Nov 3 2007, 03:30 AM
Anyone have a pic of the stock washer?
Is it copper?
aluminum?
stainless steel?
plastic?
How much do you guys tighten it? Do you make it as tight as possible with a normal socket and ratchet?
Thanks.
BTW, I just did my oil change and I simply used the washer that was already on there (iirc, it was aluminum).
Its aluminum.
As far as tightening I hand tighten snug. If you try to tighten it as much as it will go you'll strip the threads, constant overtightening stretches threads and eventually you'll have to re-tap them. I'm sure theres a torque spec maybe 7-12 ft lbs?? dont quote me on that.
Old 11-03-2007, 04:51 PM
tinkfist's Avatar
There is a torque spec for just about every bolt on the car. This one is 29 ft-lbs. I would not worry much about the crush washer, but the teflon tape idea sounds like a good one if you are going to do anything
Old 11-03-2007, 05:04 PM
jeggy's Avatar
i forgot the crush washer on my car for the past 2 consecutive oil changes. no leaks. i just keep and eye on it. quick peek under the car for any puddles.
Old 11-03-2007, 05:09 PM
GinoGT's Avatar
I never understood this crush washer on the drain bolt business. Plenty of cars don't use them and don't leak. Does it have something to do with the oilpan being aluminum?
Old 11-03-2007, 08:53 PM
stopmenot2002's Avatar
Scroll down for the washer picture. just loose it abit, get wash ready, then slide out bolt while slide your finger right after bolt is off, the hole it there so you can put washer on and do the opposite.
Old 11-03-2007, 11:36 PM
Sponsor
JS2k.com's Avatar
Thanks,
I removed the bolt then quickly added the washer without losing too much oil. still a mess tho.
I s2ki.
__________________
_________
Quick Reply: Oil change - forgot to put on crush washer
