Oil change - forgot to put on crush washer
Sponsor
Worse than reusing an old crush washer, I completely forgot to put it on! The new oil is already in.
should I?
1. Loosen and quickly put washer and bolt in before too much oil comes out and on my hand. Then refill lost oil. (leaning toward this much more than #2
2. F*** it. (not a very good option.. but it's still an option.)
3. Suggestions?
should I?
3. Suggestions?
__________________
AP1 and AP2 Clear Headlight Diffusers!!! - Clear out your S2000 headlights!
LED Conversions for all S2000 lights
Keyhole Covers - Get the Shaved look
Oil Drain Valve - Easiest Oil Change ever!
_________
For LEDs for your other cars, head to our new website: SupernovaLEDs.com. Same great quality, easy-to-use website. Pick your car, we'll show you what fits.
_________
Option 1.
Its as simple as keeping constant pressure on the screw as you are unscrewing it and as soon as the bolt is off stop the flow with some thing, and with other hand throw a washer on the bolt and with once again pressure screw it in.
Man that's gonna be messy.
GL lol
GL lol
if u can.. just take it out really quick and put one on
most likey u lose like 1 qt.. even if u lose more.. u still wont lose all of it.. and refill it..
but if u lose it all.. than free engine flush... also suck at working fast lol
Anyone have a pic of the stock washer?
Is it copper?
aluminum?
stainless steel?
plastic?
How much do you guys tighten it? Do you make it as tight as possible with a normal socket and ratchet?
Thanks.
BTW, I just did my oil change and I simply used the washer that was already on there (iirc, it was aluminum).
Is it copper?
aluminum?
stainless steel?
plastic?
Thanks.
