Oil change before winter.
Old 11-12-2014, 09:09 AM
  #21
jkelley's Avatar
Originally Posted by Saki GT
If the car is sitting in storage, the oil is sitting in a pan in storage - same basic principle. Why change the oil before and again after, with zero use? Just let the old oil sit and replace with fresh oil when the vehicle re-enters service.
I guess I just have this image in my head that any microscopic sediments in the oil would have enough settle time to conglomerate. That's just what happens to some stuff in my industry with about the same consistency of oil. However I think you're right, I'm pretty sure oil is engineered to remain a homogeneous and uniform suspension at extended sitting intervals (3-6 months). So I probably worry about nothing.
Old 11-12-2014, 10:15 AM
  #22
Car Analogy's Avatar
Received 1,439 Likes on 1,071 Posts
Hopefully that isn't true. Hopefully oil is also coating the interfacing surfaces such as rod and main bearings, cam bearings, cam lobes, timing chain, etc. So that on startup, there is some protection against metal-to-metal before oil pressure.
Its this oil, coating these sensitive surfaces, that you want to be concerned about, not merely oil coating the inside of your block, or pan.
All that said, I agree if the oil is servicable, its fine for winter storage. If its near changing, and you were going to do it in Spring anyway, I would suggest changing it prior.
devun157
09-10-2006 04:52 PM
blackfx35
11-29-2004 06:53 AM
Fapout
02-16-2004 06:45 PM
vmb
12-08-2002 05:17 AM
Greg Fisher
10-22-2002 10:00 AM
Quick Reply: Oil change before winter.
