oil change before the recommended date?
Old 06-05-2005, 07:13 AM
xviper's Avatar
i'll just add a little bit of oil before my tahoe trip this week.
Before making any sort of lengthy trip where you may be away from home and services, you should always top the oil up to the "FULL" mark on the dipstick. Although it is safe to run the engine with the oil anywhere in the "X's", you should do a cursory inspection of any vehicle before a trip. Part of this inspection is to make sure all fluids are in good order - oil, coolant, brake/clutch fluid, tire pressures, washer fluid.
Viper mabey you could find those threads
https://www.s2ki.com/forums/index.php?showt...dpost&p=3285584
raisantos
11-01-2007 01:36 AM
brunodkid99
11-14-2006 09:32 PM
naseeb
11-16-2005 05:35 PM
subzero
02-12-2004 04:35 PM
supernig
02-03-2002 07:02 AM
Quick Reply: oil change before the recommended date?
