Oil Change!!
Oil Change!!
Today i change my oil and oil filter only 41/2 quarts came out of the engine....the oil was full before the change!!! I thought the S2000 take 5.1 Quarts????
Banned
yep, same finding for me too, about 5.5 to get it at a nice full level on the stick. A lot of factors are involved including whether or not you drain it hot or cold, and then when you check the oil. Like cdelena said, it takes quite a bit (1/2 quart) to fill the filter up so you probably had about 5quarts in the motor which is fine..... unless you are saying it had 4 1/2 quarts when you dumped the filter oil into there too, which would mean you either burnt a little oil between the changes, or you didnt top it off enough the last time you changed the oil after the oil filled the filter completely.
LostWaffle
03-15-2004 06:54 PM
