Oil catch can help
Old 08-31-2012, 08:05 PM
JackBeNimble's Avatar
PCV>Catch can>Manifold. Got it, thanks guys
Old 08-31-2012, 09:26 PM
xviper's Avatar
Originally Posted by wing
Waiting for my catch can, I emailed them for the dual setup, no reply yet.
Can I T my breather and pcv connection to one catch can in the mean time?
Did you get a sealed (closed system) or open can? If you are using a sealed can, then you shouldn't "T" the 2 lines together because you are boosted. Intake manifold pressure builds up when under boost and if you are still using the PCV inlet to the intake, boost pressure will push through and into the front breather, pressurizing the valve cover. You can "T" an open can but then the PCV inlet to the intake need to be plugged, otherwise you'll just be boosting out the catch can. With my open system and "T", stock PCV valve, PCV inlet to intake plugged, daily driver, over a period of about a year, I get a total of about 100cc of fluid, 90% of which is water condensate, the rest oil, this in about 15,000 Kms. 10 years boosted, last 4 years with high boost pulley, fairly consistent catch can contents. I don't track.
Old 09-01-2012, 05:22 PM
wing's Avatar
Intake plugged. Open system , decided yo skip the t and just send the breather to open air and the pcv output to the can and leave the other end open to air with a filter
SilverStreak476
05-16-2012 06:20 AM
banflu
11-28-2010 09:19 PM
wisdom
01-22-2010 03:37 PM
SPLNDID
12-23-2007 07:26 PM
SIIK2NR
10-07-2005 04:22 AM
Quick Reply: Oil catch can help
