oil in air box
Old 08-15-2010, 07:49 PM
hontoy's Avatar
Default oil in air box
hi guys i got a problem i opened my air box and under the filter at the bottom was a pool of red oil which im sure is transmission fluid where did this come from can someone help please thanks
oh i bought the car 2 weeks ago it drives fine other then that thanks guys
Old 08-15-2010, 08:00 PM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
does it have a K&N type of cotton air filter ?, if so it is likely air filter oil which would be from a slight over-oiling of the filter during servicing. It would not be transmission oil as it could not get up that far and our transmission oil is not red.
Old 08-15-2010, 08:01 PM
INTJ's Avatar
Even the factory filter has some light oil on it.
Old 08-15-2010, 08:11 PM
hontoy's Avatar
hi yes its a k & n filter i just checked on the westsite they come preoiled i freaked out and cleaned the oil how much do think i need to put
Old 08-15-2010, 08:36 PM
ahrmike's Avatar
The best method I have heard, if you have time, is to oil it liberally and cover it with a cloth and leave it overnight so the cloth will soak up the left over oil
Old 10-04-2011, 04:29 PM
General_Yaj's Avatar
Same thing happened to my car too but oils aren't red....so I wanna is what caused this to happened??? N yes my filter all stock frm factory
Old 10-05-2011, 07:13 AM
INDYMAC's Avatar
Some engine oils are red (LE and Redline for sure). It wouldn't hurt to replace your PCV valve just in case it is engine oil.
PrecisionS2K
03-17-2008 09:36 AM
Fr3AkAzOiD
04-02-2007 12:50 PM
s2ksimon
11-06-2002 06:53 AM
Quick Reply: oil in air box
