The Official "MOD to Stay Away From"
#141
s/s brake lines have zero gain from what I can tell
stainless steel clutch line feels identical to stock as well
single exhaust as wayyyy too loud, learned that the hard way. now i'm dual even though I hate the thought of dual exhaust with a single header
deleting the a/c seemed like a great idea since i'm always top down with the a/c off, however I forgot that you need a/c for defrost when you get stuck in rain...
#143
Originally Posted by XclusiveAutosports,Nov 2 2006, 09:41 AM
A boost controller works the same on every turbo'd car out there, they simply raise boost above what your wastegate spring could do on its own. Whether its manual or electronic, they do the same job for the most part, but they are only dangerous if you do not tune for the higher boost levels. More boost without fuel is a pretty big mistake.
#144
T1R lightweight pulleys are crap.
After 1 year I had the bearing go bad in the autotensioner pulley which caused the pulley to slowly grind away at the tensioner making it unusable. Also, the idler pulley on the block had a 1 MM groove from the belt in just 1 year on a non-DD S2000. The only ones that haven't yet failed is the one everyone said would be the first to go...the waterpump and the alternator.
kayvan_pour
02-16-2006 08:38 AM
