OEM vs Aftermarket thoughts
I just wanted to get some opinions on aftermarket over OEM parts and upgrades. I watch a lot of car shows and to really make your car your own and make it unique you add custom mods to make it stand out from the rest. This is something I slowly want to do, and have some ideas but I'm not sure if I'm wasting my money and time.
For example, MVP motorsports has this product with this claim –
Unorthodox Racing Lightweight Pulley Set for Honda S2000 - Stock Diameter
Part # UR 040601312
Unorthodox Racing's Pulley Set for the Honda S2000 not only adds a nice touch to your bay but also produces a nice power gain as well. On average an 11-15 hp increase can be expected with the decrease in rotational mass. These pulleys are an incredible .78lbs vs. the factory 6.31lbs.
Pulleys pictures are the alternator and crank pulley. This fits all years S2000.
MSRP $323.40
Your Price$294.00
Now I think that would really look nice in my engine bay and replacing these pulleys and tensioners isn’t a bad idea. Is this claim about increased HP true?
Another good example is this -
**NEW PRODUCT** Berk Technology Honda S2000 50mm Exhaust Manifold/Header
Part # Berk BT1615
Uses large port 50mm primaries & high flow CAD designed 63.5mm collector (2.5"). Optimized for use with aftermarket exhaust and/or test pipe. Perfect compliment to the Berk Technology 2.5" test pipe. Polished 304SS. Includes secondary wideband O2 sensor port for fuel tuning. One of the best performing headers for the AP1 & AP2 S2000.
MSRP $499.99
Your Price $449.99
My question is are aftermarket parts worth the money and claims? if so what aftermarket parts due the S2K good over ones that are a waste?
Part # UR 040601312
MSRP $323.40
Your Price$294.00
Part # Berk BT1615
MSRP $499.99
Your Price $449.99
I dont know if I would believe those power gains with the pulleys.. I've never changed mine out, I probably wouldnt waste money on something like that.
As for the header, you wont really see much gains by itself but if you pair it up with a more free flowing exhaust and TUNE for it. You'll see some gains. Id do that before I did the pulleys.
I think they ment .11-.15 hp
There is no HP increase. However, any reduction in rotating mass can have a greater effect than HP. Less work for the engine. I have alum pulleys myself. Not underdriven.
I am NOT a fan of changing the stock crank pulley, I think its a bad idea for vibration damping reasons.
Thing is i dont want to lose the stock sound of the exhaust, or change it to the sound of a ricer civic that sounds like a lawmower at full rev. I want something in terms of exhaust that sounds like stock or deeper. Any ideas?
Regarding sports cars-and I think the s2000 qualifies-it's very difficult to improve on oem without running into some compromising. The OEM engineers have more resources and experience/data than any aftermarket company out there. The cars arrive as they do as a result of carefully chosen tradeoffs and in the case of a sports car, it's usually cost/performance (as opposed to sound/comfort/design, etc).
As an example, if you want more road feedback and stiffen up the bushings, you're going to get more vibration. If you want faster rpm/engine response and lighten the flywheel/driveshaft, you'll need more rpm starting from standing. If you want more hp via FI, you either have more heat (turbo) or noise (sc). There is no free lunch so to speak.
This graph seems to show a fairly decent amount of improvement in dampening and my local hot rod builder swears by them and he builds big budget 2000hp drag cars all day long.
As for exhausts I think the best off the shelf onese I have heard are the t1r sparrows, I really like the 70mm single
http://www.scienceofspeed.com/produc...1r_70r_sparrow[2].jpg
I do little bit of aftermarket parts on my car even I'm not big fan of aftermarket.
Not because I want to gain more HP or anything but trying to look different than others. Makes it unique like you said.
Unless you're going to track your car or putting your car in for show car etc, I wouldn't invest too much money into it.
In fact, these days... you get more attention even if your car is simply clean
