OEM Tonneau cover
It seem like I large hands since I can't get it in all to tack on the buttons. Yeah, the buttons seem to be shorter from where the clips come out on the roller bars. I thought it would be nicer to have on in the summer or when driving around where there are a lot trees, so leaves won't get in. It was a good idea but doesn't work to well. Thanks guys
Make sure that the rollbar above your head when the top is up is pushed backed when you put the top down. when it isn't folded right its hard to get to the snaps. 02+ models don't have the middle snaps because if the glass hitting them.
You also might try just leaving it in the sun a little bit before putting it on the car. I have a 2007 and have used mine only 4 or 5 times and every time the rear snaps take a while to grab. Like you, sometimes they just don't seem like one will reach after the other is connected. I found if the cover is a little warm it helps it stretch so it fits and everything is nice and tight.
