OEM suspension adjustments?
hey all,
i recently purchased an 03 white/tan s2k. I have been saving for this car for years and it is everything i had hoped for.
Ive had the car for about a month and have noticed that the allignment is off by a couple degrees. I was talking to a friend who said that i might be able to adjust camber and toe even though i have a totally stock susp. Are there adjustables on oem suspension parts? If so is there anything else that i should think about? Also will the extended warranty cover that kind of adjustment.
no warranty on the suspension adjustment if you doing it yourself of course.
the toe, and camber is adjustable, there's just enough adjustment for the double wishbone suspension, unless you are doing something extreme like drifting, or racing.
and no warranty on the alignment spec that i know of, unless you drive a NSX and all your NSX buddies are getting cord'ed tire at 7k (okay, no more nsx joke)
Originally Posted by Boofster,Aug 13 2007, 12:25 PM
What u talkn' bout? We have real-time dynamic camber. You know, like iVTEC but iCamberTec. I can stick to the wall if I wanted. Spider pig, spider pig, do what a spider pig does.....
Camber, caster and toe is adjustable within limits. You need to find a shop that adjusts to exact specs instead of just within a range. Race oriented shops are what you should be looking for or get a recommendation to a place.
Mike9000
09-01-2007 01:34 PM
