OEM O2 sensor electrical connector....can you buy one separately from the O2 sensor itself?
As the title states, I'm trying to source a secondary O2 sensor electrical connector (the one for the O2 sensor that plugs into the cat) for my 2007 S2000. Can you buy the connector separately from the O2 sensor itself? If not, how would I go about obtaining one?
Thanks in advance!
Thanks in advance!
So I called the local Honda dealer and it seems that you can't just buy the O2 sensor electrical connector, you have to buy the whole O2 sensor! $288!!!
Does anyone here have (or know someone that has) a bad O2 sensor so I can use the electrical connector?
The connectors are differant for the front and rear 02 sensor. One is male and the other is female and they can be mated. So it depends what one you are looking for. Post a want to buy thread in the want to buy forum. A spare can be found on an engine harness as the secondary o2 connector on the engine harness can be used to connect to the primary o2 connection.
I know this because I have done this for my AEM EMS wide band installation.
So why do you need his anyway? I might even have one as well.
I need the connector that is attached to the rear (secondary) O2 sensor. It should look like this:
Unfortunately I can't post a WTB thread because I am not a member!!!
Are there any U.S. suppliers for a part like this? I can't imagine the shipping being cheap from the UK...
I honestly have no idea if they are the same (I would think the connectors are the same.... but I am not sure). I am still new to S2000s and Hondas in general, so I'm sorry for not having that info!
If the connector looks like the one in the pictures below, then it's what I need:
I need the connector on the left:
