OEM Front Lip fitting
I installed my OEM front lip and the front center portion is about 1/8 inch off the front bumper. Is this normal or how do I fix it?? I have a pic, but how do I post on the actual posting??
Don over tighten the 10mm.. Just enough so its tight. Ravenwerk is right. There should be a rubber seal along the edge of the lip and should be flush on the front bumper.
jbotstein1,
The bolt holes in the lip tabs are larger than necessary. Try the tightening sequence starting in the middle of the spoiler first. Press in so the lip is flush before tightening. Put the end screws in last. Hope that helps. Is is possible that the front end has been damaged in a prior accident enough to warp it somewhat?
Good luck.
Good luck.
mattie170
07-13-2015 12:39 PM
