OE Honda or aftermarket o2 sensor
Hi. I got CEL code P0135 Ho2s a/f sensor s1 heater circuit. After researching on here it seems like its the Heater circuit bank 1 sensor 1 which is the primarily o2 sensor on the header. If I assume wrong can someone let me know.
So my question would be do I buy a OE one from Honda or an aftermarket one. Which ones do you guys suggest ?
Thanks in advance
Thanks in advance
Would there be any differences if I went OE vs aftermarket ? I know some stuff you should get OE and not aftermarket. Would this be a part that doesn't really matter which route I go with ?
ok question, which one is it? the options I am given are:
1) Denso Air Fuel Ratio Sensor Direct Fit (Upstream) Part No. 234-9065 ($221)
2) Denso Oxygen Sensor Direct FitPart (Downstream) No. 234-4353 ($331)
3) Denso Air Fuel Sensor Direct Fit Part No. 234-9055 ($212)
Also, are those prices pretty much it or am I not looking at the right places? Whats the going price range for O2 sensors?
i got the OEM denso from adavance auto for $80 shipped, its the same sensor that you would get from the dealer, without the mark up price. go to their website and get the one for upper stream and use their 40% off coupon code (FABU) enter that at checkout and they will ship direct from denso. the same sensor that the 00-05 s2k's came with from factory. its $115 but minus the $40 and it comes out around 75 plus 5 tax and free shipping.
The upstream oxygen sensor in this schematic is labelled lambda sensor and the accompanying articles describe what it does.
http://ngkntk.co.uk/index.php/techni...bda-sensor-do/
http://en.wikipedia.org/wiki/Oxygen_...e_applications
http://auto.howstuffworks.com/question257.htm
