Odd squeek from rear suspension?
Old 11-18-2013, 03:50 AM
iamxpl's Avatar
well if its never been changed there should be no reason for it to be adjusted.
its easy though. loosen the fastening bolts to the sway bar and leave it disconnected. also any bushings and adjustments. back the car up on ramps * DO NOT just simply lower them on the ramps/platform as it will not let the tires move as they should and settle in to place where they should be. then you tighten all the bolts and nuts while the car is on the ramps. get yourself a beer its pretty tight and you will be on your back the whole time.
Old 11-18-2013, 11:22 PM
2leftshoes's Avatar
It seems like it happens more noticeably specifically when the spring/strut compresses and decompresses.
Any other ideas?
Old 11-19-2013, 12:37 PM
Car Analogy's Avatar
Received 1,470 Likes on 1,086 Posts
Well when the springs compress, the swaybar also slides in its bushings. So like someone else already mentioned, the bushings might need to be lubed.
Old 12-06-2013, 12:57 PM
2leftshoes's Avatar
It mostly resembles the sound of metal scraping another metal. I was wondering if theres anything that can rub against my 17x9 +45 rpf1's on the inside without me knowing?
bmxer882x
07-25-2012 05:22 PM
txchopper5
01-30-2009 10:39 PM
thebig33tuna
10-02-2008 09:05 AM
moff
09-07-2007 11:32 AM
bluedd
10-25-2004 10:11 PM
Quick Reply: Odd squeek from rear suspension?
