Odd Squeak from rear
Wondering if anyone could help me out having the same problem before.
I started hearing a squeaking noise coming from what sounds like the driver side rear wheel.
It goes away when I am on the gas or riding through a downshift.
It does not change noise or pitch when i brake, or e-brake for that matter.
Once clutch is pressed in you can clearly hear it. The closer to stopping I get the more dragged out the squeak gets (if that makes sense).
The odd time i can hear it while im on the gas, or cruising slow.
Is this a simple wheel bearing fix? I already checked the dust/brake shield and pads are coming off tonight.
Any help is greatly appreciated.
Almost exact same as this video.
[media]http://www.youtube.com/watch?v=Fsw_EwnUcGU [/media]
Also thought I'd add there is no droning noise when cruising at higher speed like normal bad wheel bearings.
Almost suspect it's the pads, but thought I'd ask around before I tackle it tonight.
suzukawoods
01-11-2006 09:18 AM
