Odd noise?
Odd noise?
Ok i did my research on this noise, but i need some advice on my particular situation because of my lack of experiance.
From a dead stop, easy accel you hear a noise sounding like you ran over a nut in the road. It will also make thise noise when i go in reverse from a dead stop. It does it one time, and does NOT do it when im driving. Based on my research it sounds like ball joints? Or rear end problems? I have a 2000' Ap1 with 64k miles. I would like to know what to say to the dealer? I dont want to go in circles and waiste money, i want the problem solved, but i dont know how i should approach them, and the correct terms to use. Is there a TSB? I APPRECIATE ALL HELP
Seems like you've got the rear axle nut problem. There is a TSB but I can't tell you the number. The rear hub nuts must be removed, the area lightly greased, nut put back on, BUT with the higher recommended torque of 221.
