OBD2 extension cable
Has anyone found an OBD2 extension cable that works with my USDM MY06? I mean that will actually plug into the car and stay there? I've tried two different cables and I can't get either to plug in securely under the dash.
Or an I doing something wrong? Trying to plug my Hondata Flashpro or a port reader requires gymnastics my olde body ain't built for anymore. Both plug in perfectly as does the smog station connector. I'm thinking a 12" extension will just stow under the dashboard and be accessible when needed.
-- Chuck
-- Chuck
Strange. I bought a cheapo ribbon style OBDII Y-cable to run two monitoring devices off of it. It stayed in there just fine. If I remember correctly, there's a locking type feature on the connector to keep it snug to prevent it from falling out.
Thanks, I'll keep trying.
Seemed strange that some work (FlashPro, etc) and some don't. Car is in a position for the winter that it's nearly impossible to try again for a while.
-- Chuck
-- Chuck
Can you provide more details on the two monitoring devices you are running? I tried running two using a Y-cable as well, but only would function at a time.
Originally Posted by aphex4000' timestamp='1456162059' post='23887593
[quote name='99SH' timestamp='1456101855' post='23886967']
[/quote]
Thank you!
Fat
04-24-2017 06:55 AM
lewiS2K
12-07-2011 08:08 AM
