O2 sensors, why do they go bad?
#22
other than those, i've done extensive electrical work replacing all the bulbs in the cluster and controls (hvac, radio, roof/hazard) with lots of leds. Also, the turn, sidemarker, lic plate, dome, trunk lights have been replaced with leds.
Come to think of it... only the HID's, reverse lights, and the 2 little bulbs that light the front of the tach are stock. everything else that lights up in the car is LED.
This was all done nearly a year ago though.. never had any problems.
#23
Originally Posted by Slows2k,Feb 8 2006, 06:39 PM
Air pump control solenoid gets moved with the SC install. It used to be mounted ont he stock airbox. make sure the wiring to it is intact, not chaffed/cut/chewed. etc.
Basically, you're saying the wire has probabaly chaffed and touched a metal contact somewhere in the engine bay, right?
#26
also, these 2 items caught my attn on your added list above:
cruise main switch
Gauge assembly on 00-03 cars
I believe the LIGHTING to the cruise main switch and Gauge assembly are on a different circuit ('small light' or 'int light' fuses i think). So this should rule out any of the lighting mods of mine, eh?
cruise main switch
