o2 sensor ?
o2 sensor ?
So I tried searching for my answer here and google but couldn't find what I was looking for.
My qustion, is it bad to touch the o2 sensor with your bare hand. I don't know if I messed mine up by trying to rub off a mark that was on my o2 sensor.
There are 2 factors.
1. I rubbed the sensor to try and get a mark off.
2. I just installed a header back system (I was running a test pipe with another exhaust) with a different anti fouler (same setup but with steel wool in between the two plugs). Would of used mine but I spot welded it onto my test pipe.
I guess process of elimination is in order
1. A new fouler; like my old set up (NEVER threw a code).
2. Try and new sensor (expensive to find out mine is still good)
Thanks in advanced.
Thanks in advanced.
I doubt that touching the sensor would really mess anything up. As long as you aren't clogging up the little "fins" then I wouldn't worry about it.
Any oils on your finger would get burnt up pretty fast due to exhaust gases.
