Normal Start Up?
Normal Start Up?
I've got the clutch depressed and I don't touch the throttle. Maintenance light is flashing because I've not reset it after an oil change.
04 with 104k on the clock
Tracked 2 times, once recently
Oil good and new
Car otherwise runs well, with a slightly lumpy idle since it began starting this way.
http://www.youtube.com/watch?v=wACyVPM2jWM
Oil good and new
Do the idle rpms continue to be a bit erratic after that or is it just that short burst and then it settles down ?.
I would look into cleaning the IAC valve, and possibly the MAP sensor (whack or clean with electronic parts cleaner) and spraying down the small orifice that goes under the MAP sensor into the manifold.
