Noob strut tower/ question
Old 09-26-2010 | 08:18 AM
shwinkwhite's Avatar
Default Noob strut tower/ question
Ok just curious, what do A and B adjust? or do they adjust anything at all? If I remember correctly this is where caster-camber plates where installed on my mustang.
http://i895.photobucket.com/albums/ac158/s...susppics001.jpg
Thank you
Old 09-26-2010 | 08:41 AM
TheMuffinMan's Avatar
Adjust? They don't adjust anything?
A holds the suspension's tophat to the car - you remove those bolts to remove the suspension.
B holds everything together for the suspension. That bolt holds the tophat down over top of the spring and strut.
You don't want to adjust/loosen/etc any of that stuff.
Old 09-26-2010 | 10:54 AM
Moddiction's Avatar
Former Sponsor
That is the top of the shocks there... You tighten them down as said above..
Old 09-26-2010 | 05:14 PM
spets's Avatar
Mustangs have a MacPherson strut suspension, which is why you can have camber/caster adjusters at the top of the shock tower on those cars. Honda S2000's have a double wishbone suspension, which is different.
A is what bolts the shock/spring to the car body. B holds the shock and springs together. If you ever take the spring/shock out, removing B allows you to separate the two.
FYI, The S2000 has camber/caster adjustments from the factory.
Old 09-27-2010 | 03:35 PM
ok thank you. One of the A's was finger tight so i tighten it a bit but not very much. How tight should each one be?
Old 09-27-2010 | 03:49 PM
Moddiction's Avatar
Former Sponsor
Believe it is 36 ft lbs.
Old 09-27-2010 | 05:44 PM
Greg W's Avatar
On aftermarket adjustable coilovers, B also adjusts rebound damping. But as said above, on OEM it tightens the tophat (which retains the spring over the damper) to the damper "rod".
ICATCHER
07-09-2015 12:17 AM
mbh69
01-06-2012 02:22 AM
s2k dre
11-28-2006 09:18 PM
ejis
09-15-2002 11:39 AM
