Noise when accelerating
Dont bother with that procedure, it wont work. Especially 180 ft-lbs you might as well not even use a nut
Go here man:
https://www.s2ki.com/s2000/topic/929...e-nut-tsb-diy/
Go here man:
Good information on the Outboard Joint and the Wheel Hub as well as the Wheel Nut TSB. I will give the wheel nut a try but the outboard joint may be more than I am prepared to do. Don't want to make things worse..............
Go here man:
Go here man:
Thanks for the link Billman! I give this nut thing another round of go and report back to see if the noise is still present. Maybe I just didn't move the nut far enough?
Are the clicks increasing with speed?
Mine is having a similar issue. I replaced one of my axles tonight (found out they had reman axles in there).
The noise and vibrations have cut in half. Im gonna get another axle in the otherside and ill post results.
Btw im MY00 with axle spacers.
