Noise Question
Old 02-28-2012, 07:15 AM
walksincircle's Avatar
Originally Posted by s2000maniac
the more owners the worse it gets....
whats your problem?
Old 02-28-2012, 11:09 AM
niick's Avatar
Originally Posted by walksincircle
Hi
Have a 2006 with 31k miles that was making a similar noise sounded like a skill saw. Changed the differential fluid and reduced the noise by 80%. Still have the noise when the car is going 42 or 43 mph in 2,3,or 4 gear. A tap of the gas pedal makes the "saw" sound. Anyone have any ideas on the cause?
Thanks
Sounds a lot like my problem, I've come to the conclusion that it's just the rear differential. This is my first rear wheel drive as well as first sports car so I wasn't used to hearing something like it.
Originally Posted by s2k-tilldeath
Try this - https://www.s2ki.com/s2000/topic/923...__axel+nut+diy
Did it to my car just because it's suppose to be done. My buddy had noise from the back of his car and he did it and it's much better now.
Thanks, I saved the article. I'll be sure to take a look at this
Old 02-28-2012, 11:59 AM
Thanks for the reply, re-torqued the axle nuts almost got to 60 deg increase, using 1/2 inch with added pipe. Will try to find 3/4 inch like billman mentioned. I think you are right about the differential fluid. Before I changed mine, the noise was loud and random at various speeds, but now is isolated to 42-43 mph regardless of gear.
harryw66
10-04-2015 01:50 AM
Tooshayx
05-16-2010 04:57 PM
s2kdriver80
01-21-2009 12:04 PM
Stiggywig
04-21-2008 07:20 AM
s2korea
11-05-2007 03:05 PM
Quick Reply: Noise Question
