Is this Noise Normal for Early AP1s?
Yours is Oem? It's not going to damage anything if that's why your asking. Just another quirk, of which this car has plenty.
The sheet metal heat shield between the exhaust header and battery can "ring." It's supported only at the bottom side. Resonates from engine vibration. Usually reported in lower rev range. Fades at higher rpm.
To test you can take it off. Then put it back.
only9k
09-18-2012 01:57 PM
