noise from front passanger wheel
hey everyone i recently had lowering springs installed on my car and before that I had my fenders pulled/rolled. The other day i gave a little too much gas going around a corner with my sister in the car and spung out. I ended up doing a 180 and was found backwards after i stopped. I did not hit anything it was just a little spin out but for some reason my front passager wheel is making a noise when i turn or hit bumps. To me it sounds like the tire is rubbing on the fender but it never did that before. Could my spin out have messed something up?
Probably. Maybe a combination of a bad install and the spin out. Maybe something wasn't tightened down right and the spin made it come loose. I would take your wheel off and check everything for signs of rubbing and see if anything is loose that doesn't seem like it should be. Make sure your lugs are tight too.
