noise after hard driving..
So today afterdriving the car pretty hard- i come home and hear a definet louder knock then i usually have. i turn off the car- wait about half an hour and start again- sounds normal (about as normal as itss going to sound). is this normal? i didnt record it- i will try next time.
Originally Posted by SpitfireS,Jul 26 2006, 02:42 AM
What engine oil are you using?
How long has it been in there?
It could be the summer heat.
(affecting you, not the car )
Biz, these motors are just NOISY! I went through the same paranoia...
Obviously, I'm not saying there's nothing wrong with your car, but if you've already taken it in to a shop, it hasn't thrown any codes, and it feels fine, it just might actually be fine.
Where are you? Maybe someone here can meet up with you to listen. If you're in SoCal, I'd be happy to.
Dave
Dave
If it's noisy when hot but quiet when cold, doesn't sound like a valve adjustment problem.
I started having similar noises and the best match I found here was timing chain tensioner. A search gave me some good ideas of how to diagnose it further.
HTH,
PEter
HTH,
PEter
Dave
Dave
I know this may sound stupid, but did you check oil levels around the time of the knocking or shortly after?
Reason being is that I had a similar situation with a friends S, where after a long hard group drive there was a pretty loud knocking from the outside of the car. Checked it out and noticed the drive burned up quite a bit of oil. I added some oil before taking any other steps. Let it cool down and restarted and its been fine since. This was about 3-4 months ago.
Has your car made any noises since? Again, what engine oil are you using?
I really doubt its the timing chain tensioner... I believe that makes more of a rattle than a knock.
