Noise!
Did you ever determine what your issue was? I have a whine in neutral/idle and revving as well and don't know what the issue is.
@Billman250 Do you have any idea what this could be?
But the symptoms you describe IF indeed coming from the trans, can only be one of two things. Either the throw out bearing or secondary shaft bearing/s in the trans.
I have a question about "I have a whine in neutral/idle and revving as well and don't know what the issue is." does your sound increase with revving? My secondary output shaft bearings were toast and replaced with positive results, but the noise for my car was 100% speed dependent. In gear, out of gear, turning, in N with the engine off, the noise was always there, and built up with speed.
I could tell it was not the diff or wheel bearing by lifting the center tunnel cover (arm rest and cupholder) and having my wife put her head near that area and listen. As well, the sound did not change when turning left or right, so I could tell it was not a wheel bearing, or a diff bearing outputting to the axle. When I changed my secondary output shaft bearings my noise was 100% resolved.
