No start, please help
I drove it to work, parked it for 11 hours,
Now, not starting
Good power
Good spark
Fuel to the fuel pressure damper
Relays are good
Fuses are good,
Where do I go next?
Now, not starting
Good power
Good spark
Relays are good
Fuses are good,
Where do I go next?
"Not starting" = engine not turning over? Or it's turning over, but not running?
Thanks!
Thanks!
How fast is the starter spinning the engine? Just a few turns and then some rapid clicks?
-- Chuck
-- Chuck
I had this issue with my civic last year and I had to play Sherlock Holmes. 3 things make an engine run.
- fuel+air+spark
For me it was weak spark from a failing distributor rotor (the S has coil on plug and no distributor obviously). listen for the fuel pump priming to help rule out fuel- not fool proof way to tell.
I had to pull the spark plug wires and connected a tester to try and visibly see the spark jumping the gap in each individual cylinder.
good luck
darcy
- fuel+air+spark
good luck
darcy
