No spark! help please
Old 12-20-2008, 06:51 PM
ECU Pirate's Avatar
Default No spark! help please
I just finished up installing a new motor. I also installed my full race gt35 kit. Now that its all back together, the car will not start. I checked for fuel, which is fine. I then checked for spark, and its not getting spark. I have AEM EMS, and I checked under options, and all coils are checked active. I checked the ignition coil fuse, and it is good. I checked all my grounds, and they are all securely fastened. I am at a loss, and would like some advice.
thanks!
Old 12-20-2008, 07:15 PM
ChefJ's Avatar
Try the FI forum.
Make sure your connections are good on the ems.
Old 12-20-2008, 07:41 PM
Stratocaster's Avatar
Check the gound connections. The one next to the ECU and the one of the back of the head both play a role in spark. Ask me how I know
Old 12-20-2008, 10:48 PM
jzz30's Avatar
pop your stock ecu in to make sure its not the aem.
Old 12-20-2008, 11:56 PM
ECU Pirate's Avatar
The stock ecu won't run the 1000cc injectors right . Among my search results I read that cam shaft alignment could cause, as well as the crank sensor , which I will check.
Old 12-25-2008, 01:54 PM
ECU Pirate's Avatar
I ended up plugging in the stock ecu to see if i could get spark with it, and i got spark. I then hooked the aem back up, and tried starting, but after a couple turns, something popped real loud in the vicinity of the passenger side fuse box. Smoke was coming out, but by the time I got out of the driver seat to see, I couldn't tell where the smoke was coming from. Now, even with the car jumped with the battery of my other car, it will barely turn over, as if the battery is dead and not hooked up with jumper cables.
I checked all the fuses in the fuse box, and i checked the ignition coil, alternator, and ecu fuses under the dash. All were fine.
I am at wits end here, and getting fed up with this project
Old 12-25-2008, 04:51 PM
ChefJ's Avatar
Did yo urelocate the battery ?? is there a short somewhere in that line??
Old 12-25-2008, 05:02 PM
ECU Pirate's Avatar
hell, its quite possible! I did relocate my battery. How do I check for a short?
Old 12-25-2008, 06:05 PM
ChefJ's Avatar
If your battery is shorting and arcing against the body it will spark until the battery explodes or is drained. Did you install a fuse near the battery?? If so it would have popped.
Old 12-25-2008, 07:12 PM
ECU Pirate's Avatar
nah, it was mounted on the right side of the trunk on a metal mount similar to the password jdm odyssey battery mount. The connections were free and clear of anything. I just now removed the positive battery cable, and will replace it this weekend. Could that have been the underlying issue of not getting spark?
Quick Reply: No spark! help please
