No Spark? Help?
No Spark? Help?
I have a 2002 s2000 that i just recently added a stroker kit to and for some reason I am not receiving any spark through any of my coil packs. This is my first attempt at start-up and I have tried everything i can think of. I have checked all the fuses and relays, removed coil pack and reinstalled, changed spark plugs, and checked all grounds. Is there anything else significant that anyone can think of that would be causing this issue? I also broke my Crank Positioning sensor when re-installing the engine, it wasn't completely destroyed so we decided to see if it was reusable, would that have anything to do with the issue? Is there something in particular that i could have missed or overlooked both now or when putting the engine back in?
Thanks,
Jarett
Thanks,
Jarett
Well, im going to go ahead and buy the new sensor and replace it, but if the timing was off it wouldnt turn over like it does, and even if it did, it wouldn't cause the coil packs to not spark at all? We took one out, put a spark plug in the end of it, and attempted to turn it over, no spark what-so-ever. So im thinking that its either a bad ground somewhere or that sensor. I cant think of anything else that it could be?
