No Power Steering
Old 12-22-2003, 01:44 PM
labratodd's Avatar
Thanks all. Didn't know it was electric, and will try to find out the reset procedure.
Old 12-22-2003, 02:30 PM
Road Rage's Avatar
[QUOTE]Originally posted by labratodd
Thanks all.
Old 12-22-2003, 03:24 PM
Destiny2002's Avatar
Old 12-22-2003, 05:04 PM
dundonr's Avatar
[QUOTE]Originally posted by Road Rage
Old 12-23-2003, 04:54 AM
lanbrown's Avatar
Don't forget the swearing at the peecee as well. Then again, us people that don't use windows (except at work) don't have to experience that.
Old 12-23-2003, 05:14 AM
blureds2k's Avatar
Moved to UTH.
Might be able to get better help there.
Old 12-24-2003, 07:23 PM
RazorV3's Avatar
nah man u need to change out your headlight halogen fluid
Old 12-24-2003, 11:36 PM
RACER's Avatar
I pesonally think that the heffler shaft is out of balance. You might want to replace the air in your tires, probably all four off them as the air can get stale which changes its molecular structure, hence making the characteristics of regulated pressure unstable. Dude maybe you need to change the air freshener??
Are you following me?
Old 12-26-2003, 05:12 AM
TepEvan's Avatar
That happened once to me last winter and I called the dealer and was bringing it over and when the car warmed up the power steering started working and the EPS light turned off. You may not have a cold weather issue in socal, but i dunno. I would let the car warmup for about 10-15 mins and see if it's still on.
Old 02-17-2004, 12:45 PM
STL
STL's Avatar
Today, I got the car started and the EPS light came on.
Quick Reply: No Power Steering
