No power to cooling fan
My SPAL fan isn't turning on causing the car to over heat.
-directly connected the fan to the battery and it works
-fuse is still good
-relay is good
I put a 12v tester to the fan connecter and it did not light up. Not sure why power is not going to the fan plug any ideas?
This all happend after i blew the cooling fan fuse,after I replaced it with another one it didn't turn back on.
-fuse is still good
-relay is good
Check your fuse again...normally fuses don't go bad just for fun. Something caused it to go. If its blown again fix the problem first then put in another fuse.
If this is the case its either short to ground, short to power, or Jesus just no love you.
no there is no fan relay in the underdash fuse box .....the relay is in the underhood fuse box along with another 2 fuses ...1 fuse is for the radiator fan and the 2nd fuse for the condenser fan
