No oil pressure after warming
Old 06-28-2014, 11:20 PM
javimx5's Avatar
Default No oil pressure after warming
Hi All
I´m new on this forum and also new on the Honda S2000. I´m just about to buy my first one, a year 2000 S model but has an issue with the oil pressure. As soon as the engine gets warm the oil presuure drops, what could be the problem? Oil pump? any relief valve?
Any comments or help is highly appreciated.
Old 06-28-2014, 11:33 PM
Ian300D's Avatar
That's normal. Maybe your confused on oil pressure. What is it dropping to. What weight oil. How are you measuring it?
Old 06-29-2014, 12:31 AM
SpitfireS's Avatar
Most important question: how are you measuring it?
The S2000 does not have an OEM oil pressure readout, as far as I know.
If it's the oil pressure warning light: walk away from the car and do not look back!
Old 06-29-2014, 04:41 AM
nissanfanatic's Avatar
What does it mean if the oil light is amber and not red?
Old 06-29-2014, 04:46 AM
zeroptzero's Avatar
Received 3,799 Likes on 2,677 Posts
Oil pressure at hot idle can be anywhere from 13 psi to 36 psi, if you are reading from an actual gauge. It will be much lower than cold oil pressure readings, so that is normal.
If you are just using the oil pressure dummy light to determine that it has low oil pressure, do as SpitfireS has suggested and run away quickly, the motor would be toast at that point. They should re-label the oil pressure dummy light on these cars to: Dead engine light.
Old 06-29-2014, 10:20 AM
SpitfireS's Avatar
The color is irrelevant, if it's ON while the engine is running, even at a hot idle, it is a sign the oil pressure is BELOW the level it should be and that is bad news.
No engine oil availabe on the market in Europe will make this light go on, in case people start asking if the owner used a OMG!-IT'S-TOO-THIN 20 weight.
The - generic - picture I found online, I didn't really think about the color.
Old 06-29-2014, 01:01 PM
cosmomiller's Avatar
Received 1,753 Likes on 1,045 Posts
Run, Forest, RUN!!
Old 06-29-2014, 01:12 PM
Old 06-29-2014, 06:54 PM
2001-S2k's Avatar
It's time to back away from the car.. haha
Old 06-29-2014, 07:53 PM
philipminge's Avatar
EJECTO SEATO CUZ. no deal. if you see the light.... tell the guy to put a new toda motor in it and you'll buy it for his asking price.
cars worth $15.00 if that oil light is on.
fried!
Quick Reply: No oil pressure after warming
