No Oil Light
![](https://staticssl.ibsrv.net/autocomm/Content/S2Ki/milestonestars-10yr.png)
So my oil light doesn't come on whatsoever. Even when I turn my key to position II it doesn't come on at all. Any ideas on what it could be? I know it's not normal
probably a bad bulb, each of the warning lights has a dedicated incandescent bulb, and they can burn out. You should double check the wire on the oil pressure sending unit that is just to the left of the vtec solenoid, make sure it is connected and in good condition, if it is then you likely have a bad bulb.
