No Brake Light or seat belt light on Dash
So I realized the other day that my brake light and seat belt light on my dash isn't turning on? I tried putting the top down too and now that won't go down either, I'm guessing cause the light isn't on. Anyone have an idea what it could be? I did blow the 12V socket fuse the other day. Could that have done it? No idea.
Replace the fuse and check back. Turn the ignition on but don't start the car. All the lights should come on except the brake I believe. The brake switch is at the e brake under the cover. Just a pin that might be stuck
Report back
Report back
I replaced the fuse 10A fuse that went out. I turned the ignition on but DID NOT start the car and the BRAKE light comes on and goes away. The seat belt light doesn't come on at all.
This brake switch is under the center console? What pin might be stuck?
