No battery heat shield..suggestions?
Just a quick update that I received my heat shield today.
It was just thrown in a box but had the parts sticker attached as seen in the photo. Thanks to @rpg51 for recommending that I start the bolt way in the back first and then slide it into place and tighten everything down. I'll be ordering the bolts from Honda on Monday.
My car also came without the header heat shield so I'm debating if I should get one or not because that should definitely be installed first before the battery shield. All of the ones on ebay have cracks in them.
Is your header OEM? If so, my inclination would be to install that header heat shield too.
It is the stock header and I feel like I should probably get the heat shield on it as well. Finding one that isn’t cracked seems to be a bit of a challenge though. I guess it’s common for them to crack though…from what I’ve read.
dan_uk
05-13-2009 01:14 PM
wing
09-09-2005 06:58 PM
