Nitrous question
#21
I talked to nos about this system a couple of month's ago... the guy I spoke with told me that they would'nt know if it will work on our car until they try it he also told that he was working on getting an s in to test it and see if it work's so maybe by now they've done it.. the guy's name that I spoke to was nestor at nos in california.. if they have'nt gotten a car yet to try it on, does anyone want to donate theirs for the test
#22
I disagree.
I've used a 100 dry shot on my S2000 and had no problems what so ever. Till today even with the supercharger I use a small dry nitrous set up and have zero problems.
Larry
Body Werks
www.BodyWerksAuto.com
00 Custom Yellow S2K
Probably the most modified in the country.
"If you think your faster show me your time slip"
Larry
Body Werks
#23
The best nitrous kit I've seen out is from Jim Wolf Technology, which is all Nissan unfortunately. They're system includes a separate chip/programming of some sort specifically for the use of nitrous. It only engages when you arm the system and are at WOT. You get better gains w/ this since you have separate fuel and ignition maps turned for the nitrous. This is the way I'd wanna run nitrous.
#24
#25
Just looked it up, I'm not mistaken.
http://www.venom-performance.com/
Click on VCN-1000 or VCN-2000
#26
#27
Yes, this does sound good, but it still lacks a good sufficient setup. Even though it is computer programmed, it still uses a regular nozzle injector into the intake. This does not garruntee that all the cylinders get the equal amount of Nitrous, thus your are damaging your car. I believe that Direct Port or the new NOSzle system is the best way to use NOS for a daily driver setup.
#28
[QUOTE]Originally posted by Pappy
[B]Yes, this does sound good, but it still lacks a good sufficient setup. Even though it is computer programmed, it still uses a regular nozzle injector into the intake. This does not garruntee that all the cylinders get the equal amount of Nitrous, thus your are damaging your car.
#29
I don't think the Venom kit comes w/ a separate chip. It regulates the amount of nitrous based on the info it receives from the O2 sensor. Their kit is basically a universal kit. JWT kits come w/ an external chip tuned for each car that it switches to when the system is activated.
What companies make direct port nitrous kits? Any specific for the S2000?
