NGK Spark Plug info.
Old 09-20-2007, 09:49 AM
  #21
rzanys2k's Avatar
SO THE BKR8EIX IS THE BEST CHOICE FOR TURBO. CAN SOMEONE TELL ME IF THEY SHOULD BE GAPPED?
Old 09-20-2007, 10:09 AM
  #22
jojipoji's Avatar
info i was looking for, thanks
Old 09-20-2007, 10:35 AM
  #23
ShocK's Avatar
They're Iridium, don't gap them, you will knock the iridium coating off.
Old 09-20-2007, 11:49 AM
  #24
VAD
VAD's Avatar
ignition25: The "IFR" and "BKR" prefix refers to the way the plug is built (ie. 14mm thread, 5/8inch hex, gasket seat), not to the materials used. The suffix "IX" refers to iridium.
ShocK: Iridiums can be gapped with a normal gapper. It is wise, however, to be cautious not to damage the tips.
Hope that clears a couple things up.
Old 09-20-2007, 02:29 PM
  #25
ShocK's Avatar
Yeah better off not to touch em IMO, supposedly you can knock the tip off, if your retarded maybe, seems if it was that easy to come off it couldn't stay on at all lol They're welded on so maybe theres a possibility if one isn't welded to standards the tip could be knocked loose by a gauge.
Old 09-21-2007, 10:49 AM
  #26
ignition25's Avatar
So are you suggesting that this:
http://www.ngksparkplugs.com/products/spar...um.asp?mode=nml
and this:
http://www.ngksparkplugs.com/products/spar...ix.asp?mode=nml
are the same product?
Old 09-21-2007, 12:15 PM
  #27
INTJ's Avatar
Originally Posted by ignition25,Sep 21 2007, 10:49 AM
Looks like straight up marketing. Plats already last for 50-100k. Iridium has the smaller surface area and a harder electrode, so they last even longer. Laser-welded just means that there is a minor difference in production as far as I can tell.
Old 09-21-2007, 03:29 PM
  #28
VAD
VAD's Avatar
Originally Posted by ignition25,Sep 21 2007, 01:49 PM
No. I'm not sure how you inferred that. The first one is an iridium center electrode and platinum ground electrode. The second one is iridium in both locations.
Old 12-22-2007, 03:02 PM
  #29
ShocK's Avatar
To revive an older, but informative thread, I am curious as to why the IFR8H-11 is better than the BRK8EIX? Could you tell my your reasoning?
Thanks. Shock.
Old 12-23-2007, 12:37 AM
  #30
jyeung528's Avatar
i'm still confused about the iridium 7746 model...is that better than the oem 7772?
or just a publication error...since it was fixed in the 07-08 catalogue?
Quick Reply: NGK Spark Plug info.
