NGK PFR7G-11 vs NGK PFR7G-11S
Just replaced my spark plugs (@ 110,000 miles ), and I noticed the plugs I pulled out are NGK PFR7G-11S and the ones I ordered from majestic honda are PFR7G-11 without the "S" on the end...
is there any difference between these 2 sets of plugs? Aside from the missing "S" on the end, and the obvious wear and tear the originals have seen, I can't really tell a difference.
Stainless steel washer on the "S" designated plugs. The "S" plugs were used after a recall was made for the older plugs. IIRC the torque value was also changed for the plugs but I can't remember the exact number.
Update: Did a search, check out this thread.
Did more searching, here's the update bulletin for the "S" designated plugs. Looks like your car already had the service performed at some point due to the 11S plugs already being in the car.
Bulletin
The tip on the new plug looks really thin to me? I thought the PFR7G-11S had a fatter, more rounded tip?
Bulletin
i'll take your old plugs if ya don't want them.
i dunno why they allow people to purchase the non "s" when I see no viable reason why people would choose it.
I'm gonna hold onto my old plugs until I change these new "11" plugs out with some new "11S" plugs, just in case I have any problems.
I did notice the car ran significantly better with the new plugs.
Originally Posted by INTJ,Jan 14 2008, 02:53 PM
So is the current spec is still the s-variant? That is what the PDF states. I would assume that the electrode change is simply the standard redesign to the rare metal tips.
In any case, I doubt it matters as NGK kept the part numbers the same.
I'll post pics of the new 11S plugs when I get a set, probably within the week. I've got a autocross this weekend, and I don't feel like dealing with loosening plugs or misfires.
The 'S' Plugs have a PLATINUM tip and are pre gapped. The FSM say NOT TO adjust the tip may become damaged.
So the difference ins Platinum Tip and Stainless Steel Ring.
