Newbie questions about oil change
Before any of you laugh at me, I am a complete newbie to cars.
So it will soon be time for the oil change. Could anyone tell me which is the best oil to use? Should I go with the Honda Engine oil or something else.
I want to change the oil myself - anything I should know apart from what the manual says? As far as I can see I will need the following:
- Jack and two stands to keep the front up.
- Wrench to remove the oil filter.
- Torque Wrench
- New washer for the drain nut
- Oil pan
Thanks!
- Torque Wrench
- Oil pan
Thanks!
read this --> https://www.s2ki.com/forums/showthread.php?...?threadid=70348
as far as your oil choice, you need to first decide between regular and synthetic. From there, try a search and check out the gazillions of options
good luck to a DIY-er
Originally posted by 0002s
Perfect.
Thanks.
Perfect.
Thanks.
kush only
18
06-30-2003 04:43 PM
