new TCT = lower oil pressure?
i havent been paying too much attention to oil pressure as i have a mostly stock motor, but i've just noticed a change. i just recently modified my TCT. i had the worm gear sandblasted and replaced. no more chatter! however, i've noticed a drop in oil pressure at idle. used to be around 20psi warm, now its lowered to about 13psi.
should i be concerned? anybody else have similar problems?
Does the pressure return to normal at higher revs?
Do you still have your old TCT?
If so, put that back in and see if the pressure is normal again.
You didn't change oil.. did you?
S2K-F8
04-29-2017 06:47 PM
Moddiction
07-07-2010 11:27 AM
2007 Zx-10
04-01-2009 09:42 PM
